3CX V20 Paging Issues at multiple clients
Ben Bruning
Gold Partner
I've had several companies report back to me that paging has been problematic or non-functional since their upgrades from V18 to V20.
It appears the only companies that have complained have been companies that had a different dial code for paging than *8.
I've attempted at these companies to reset the dial codes back to *8 to reset this logic, per this thread:
But even after search the PBX's for quite some time for additional dial codes- I cannot find what is using *8 and making me unable to reset this dial code.
Has V20 of 3cx moved any additional dial codes outside of this menu?
Thanks in advance for your suggestions- again we've had this issue on several self hosted PBXs, all of which were upgraded from V18 and all of which did NOT have *8 set as the paging dial code prior to the upgrade.
One place to check would be the Custom Parameters - or do verbose logging, dial *8 and see what it's trying to do.
Reactions: ivank and RoryJ
As always staff immediately finds the anwser! Thanks so much- I was able to find this parameter listed a "out of office dial code" that must've been a holdover from the v18 upgrade- same with our other system.
I have updated these and will start a new forum post refering this one if paging is an ongoing issue (I doubt it will be).
Thanks again to the 3cx staff!
Reactions: KyriacosS_3CX
youwillbrun
