3CX V20 Reports
George Stavrianos
Hello to all ,
i have two issues according to 3CX V20 reports
1) Queue performance Overview report
I have created the above report, but I don't have the option to choose which queue to include in this report, and the effect of this is to display all the queues
Is there a way to appeared only the desired queue?
2) Extensions Statistics
a) i have no option to select users only department, Is there an option for this?
b) when i choose Department, then to the report appears users as duplicated, Is there a solution for this?
Thanks all
Anyone knows about that? It is import for aur company
Thanks again
No we don't have the option to create reports for 1Q or Extension....20.5 was supposed to have reporting update but it does not either
Hello, ok thanks for your answer
