Solved 3CX v20 there is no ip based trunk
leo3its
We performed the upgrade(Version 20.0 Update 2 (Build 715 Release)) to our on premise instance with Pro license and we are noticing that there is not generic profile under the sip trunks, is there any config required to add it?
Br,
Leo
Hi @bitn2 ,
Thank you for your response.
First my country is not there unfortunately, second i cannot even find this what version do you have?
Br,
Leo
Are you logged in as System Owner? You can choose a different country. Version is u3 should be the same in u2.
Yes i'm the system owner and on DE i have only these:
Not sure why is not the same i installed via ISO
Take Generic Sip Trunk, this should be fine.
The screenshot provided by @bitn2 is in Update 3. We just tweaked the label slightly to make it more clear.
Reactions: bitn2
But there still i have the authentication section which is required field @bitn2
@NicholasP_3CX should i upgrade it again?
No need, just use random characters there to fill in the field.
You are covered by the field below the authentication
Do not require.
Sure, you need to authenticate in any way to your provider. If it is ip based, just fill in some stuff, it doesnt matter.
  • Haha
Reactions: leo3its
Generic Sip Trunk:1726226020654.png
But again i don't have that option:
And seeing that 3cx is trying to register, can you please send me this provider template?
Also @NicholasP_3CX is it possible that some instances have a different list of trunks then the others?
Only if Multicompany mode is active on a PBX will there be no option for selecting the authentication method.
Have you by any chance enabled this? If yes, disable it.
Reactions: bitn2
And that was the issue, we forgot to turn it off after checking it.
For my curiosity why that option is not available in multicompany mode?
Because then the IP based provider would be in use by all the tenants.
Aha ok i see, thank you for the support
Reactions: NicholasP_3CX
