3CX V20 Update 7 Release Candidate 3
MichaelB_3CX
3CX Team
Staff member
3CX Support
Next stop - Update 7 Final.​
Following Alpha, Beta, RC1 and RC2 releases, we’re releasing RC3 to address the last minor fixes and improvements before Update 7 Final.
Fixes & Improvements
  • Loop Detection: Added protection to prevent queues from being looped.
  • Microphone Settings: Addressed issue with m
For anyone having issues with Transcription using OpenAI, as the models have been upgraded compared to what was used before, you need to allow these in your OpenAI allowed models, or it won't work.
Reactions: SteveITS
@tronic
You shouldnt have any issues coming from Update 6 to Update 7. The model used on Update 6 is kept as is when you go to Update 7.
Now in case you changed the model after you went to Update 7, then yes, you will need to add the new model in you OpenAI allowed models as mentioned in our guide (https://www.3cx.com/docs/openai-transcription/)
@tronic
Thanks for the clarification. It stopped working last update, but I never got around to looking at it till this update.
so the manger of the linux mirror decided to release RC3 as "final"...
thx..
Reactions: N_G
Cloudstar
