3cx & vTiger
penfold15
SMB User
I have an issue with Call Journaling in that it does not work. I have got the system to open the correct vTiger record (after removing the referrer check from vTiger) but it does not post anything about Call Journaling and I cannot see any errors in the logs.
Is anyone else getting issues with this?.
Did you define the extension number of your agents in Vtiger? That's important, so 3CX can map the extension number that received the call, to a Vtiger agent.
Also, please consider enabling verbose logs and checking the 3cxSystemService.log, so you can see the interactions between 3CX and the CRM.
Then, you need to edit the template as described in that thread.
We will provide an update to the template shortly to include that field.
Thats great news. There doesnt seem to be a way to tell vTiger not to make this mandatory
costionofrei
