3cx wrong password
shortcirciut
Guys, I know this was discussed a 100 times, but I am stuck.
My Login console is saying that login is denied because of too many incorrect logins.
As I have still access to the CLI ( this is a debian install ) can I change the password ?
PS. I cannot get the forgot password option, and I am sure I am trying to login with the right username.
Thanks in advance
Thanks in advance
No, you cannot reset password from command line.
BUT ;
1. You can make a command line 3CX backup
2. then open the backup (ZIP File)
3. Open a specific file with NotePad++,
4. you will be able to see the username and password.
Commands lines ;
https://www.3cx.com/docs/backup-restore-command-line/
Reactions: Charles_3CX and N_G
Thanks for the fast reply
Which file should I search ?
In the root of the ZIP folder it will have an .XML file.
Its name is random but ends with Db.
Once open, look for the following parameters :
XML:
     <Parameter>
            <Description>The admin pass</Description>
            <Name>WEBSERVERPASS</Name>
            <Type>String</Type>
            <Value>***OBFUSCATED***</Value>
        </Parameter>
        <Parameter>
            <Description>The admin ID</Description>
            <Name>WEBSERVERUSER</Name>
            <Type>String</Type>
        </Parameter>
GCLANtech
