3CXClient is blocked
daktur
Hi All,
Have anyone ever seen this error before? How to correct it?
Attached is a Screen shot
Thanks.
Is this for all or one client?
Have you tried disabling the firewall? I suspect there is a firewall issue here.
3CX Web Client is your next go to if you cant modify the network.
This is what I see on the logs:
10/29/2018 5:41:31 PM - NAT/ALG check:L:803.1[Extn:775] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop SIP proxy detected: Via:SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---Pj029acb34-c4d0-4544-b4f1-ac1ada997621;rport=5080 Via:SIP/2.0/UDP [::ffff:185.191.204.156]:39456;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.1-3a81c21b-4112-4f0f-b74d-0cf45b537622 Via:SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPj029acb34-c4d0-4544-b4f1-ac1ada997621;alias
Does it help?
Thanks again.
What version of 3CX are you running ? actual version is shown on the 3CX management console
Is the 3CX client on the same network at the 3CX ?
If remote, have you run the firewall test , and any errors you need to resolve them,
Hi @Saqqara , the client have been working fine for the last 3 days since it was setup and today started to show this error.
All my extensions are remote and the 3cx client, according to the phones menu is up to date with the version on the server.
No idea how to resolve this.
Try sending the registration email again and applying it.
Static Public IP or Dynamic?
Ensure that you can resolve the WebGui from that remote site.
Hello @daktur
Please navigate to the extension settings / Phone provisioning pick the 3CX client from the drop down list and make sure that the option " Block Presence information in 3CX Clients / Webclient" is not enabled.
WagnerFT
