Solved 3CXPhoneSystemMC01 not starting on failover sever, which services should be autostart?
KeithTX
We have a failover server setup between two linux server, the failover has worked fine in the past. This morning I SSH'd into the failover server found that the 3CXPhoneSystemMC01 service was not started. When I checked I found that all of the 3CX services were disabled for startup. I know that 3CXPhoneSystemMC01 should autostart. My question is, on the failover server which other services should autostart?
Thanks,
Keith
Hi Keith,
All of the services should start once a failover event is detected by the passive server.
So to clarify, 3CXPhoneSystemMC01 is the only service that should be running on the passive server. Is that correct?
Here is a typical example of a Passive machine running on Windows:
And a Passive running on Linux:
Reactions: liss and KeithTX
Thanks, that helps a lot.
Glad to assist!
M_R
