3cxsystemservice.log mor error
boot8024l2
can i help me? I have more same error. What happens? what is this, please? Thanks
Code:
2020/10/31 10:07:23.720|16131|0043|Excpt|System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
 ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream.
   at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest)
--- End of stack trace from previous location where exception was thrown ---
   at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result)
   at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
   at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
   --- End of inner exception stack trace ---
   at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean allowHttp2, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)
   at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
   at System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts)
   at System.Net.Http.HttpClient.FinishGetStreamAsync(Task`1 getTask)
   at _3cxSystemService.SecurityUpdates.UpdateIPsAsync()
2020/10/31 10:07:24.756|16131|0040|Excpt|System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
2020/10/31 10:07:25.792|16131|0043|Excpt|System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
2020/10/31 10:07:26.830|16131|0042|Excpt|System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
I 'm sorry . I have a problem with push notification to smartphone
thanks
Cloudstar
