Solved 4 Port Analog Gateway Suggestion
amir_
Anyone have a suggestion for a 4 port analog gateway to support elevator phones and overhead paging?
TIA,
Amir
Hi @amir_
Our supported devices can be found here. Under the FXS Gateways and ATAs you'll find a 4 port analog gateway.
Reactions: amir_
Hi @amir_
Just ordered one for testing. I have an analog DECT phone in my current Cisco topology, does 3CX support any wifi phones that I can use instead of this DECT phone?
Hi @amir_
Also, I have some Cisco sidecars for my operators that I need to replace. Does 3CX have supported sidecars or is it a matter of finding a supported Yealink phone that itself supports a sidecar?
TIA,
Amir
we use Grandstream HT 814 and 818 for our elevator and parking lot phones.
Reactions: amir_
All supported devices are on the page that was previously linked. I don't believe any WiFi phones are supported outside of the desk phones that can have WiFi added but even those are treated by 3CX as wired deskphones (no wireless configuration via 3CX). Sidecars are generally supported along with the phones so any of the supported phones that support sidecars should work.
Reactions: amir_
And regarding elevator phones, personally I would never put anything involved with life safety on anything other than a POTS line (or maybe cellular at this point if the elevator supported it).
Glad you found what you were looking for @amir_!
Kayla Norris
