407 Proxy authentication error on one system solved with +
rc179
To be clear, it's possible someone changed a setting on the 3CX that caused this I just haven't been able to find it.
I have many 3CX systems using Flowroute for the trunk, and I have always configured the main trunk DID in the 11 digit format, and all but one are still working correctly.
But one 3CX stopped allowing inbound calls. Like I said, there could have been a change I just don't see it anywhere. I eventually called Flowroute and was told to add a "+" in front of the DID in the trunk config. Well, none of my others are that way, but sure why not. And it worked.
So my question is less about how to fix it and more "why was it broken" when all the others are working fine? Is there a setting or option someplace that would make a difference?
It just seems odd that one out of all these systems is having this problem.
Hi @rc179
Flowroute sends the called number in 2 formats in 2 different SIP headers. One is with the 11 digit format and the other one is with the + format.
We have updated the template to read the SIP header with the + format to be compatible with SMS without any other changes.
Existing installations are not affected and will continue to work as they are. Newer installations must use the E164 number format.
Your issue was caused because either that the trunk was added after the template change or someone deleted and recreated the trunk or if someone saw the newer template and copied the changes over to the trunk settings.
SG_F7
