- Joined
- May 24, 2018
- Messages
- 28
- Reaction score
- 2
Check the time of your pbx, this could be an problem.
Thank you @NikosK_3CXI would recommend raising the issue using the contact form here:
https://www.3cx.com/contact/
Not the timezone, the time is important. If your clock is some time behind or in the future it wont work.hello @bitn2
Thanks for your reply. upon checking from the 3cx management dashboard, we are using the correct timezone (+8)
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
