Solved Access to Management Console from specific IP no longer available - SOLVED
arid
Our access to the Management portal was set from a specific IP address but since changing providers we no longer have access to that IP.
Can I clear this setting from the command line?
I have SSH access to the files on Lightsail.
Solved.
Setup PuTTY using port forwarding.
SSH to the Lightsail Instance using Putty.
Open the browser and use localhost:8888
The connection will be mabe to the Management Console using the local connection on the Lightsail Instance.
Tperry-NIS
