action after call
rgpelastix
Is there a way to do something after a call? For example, after a call i would like to use the callback module to call the client and with an IVR ask them if they found a solution with the agent.
Thanks in advance
Hmmm, doable but maybe not easy.
Just know what are the marco or app are used.
Using its custom part and replacing the hangup() by your own function. (new dial plan or AGI script or a GOTO(your_dial_plan,${CALLERID(num)},1) something like that)
Since Asterisk 1.6, DeadAGI() is obsolete, only AGI() is used now.
Try to find a way on voip-info.org, some stuff are there.
DejanMDS
