Active calls always empty but 5 calls is running
Jean-Luc007
My active calls listing is always empty even if I have 5 running calls.
3CX is running on Debian (Linux 3cx 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1+deb9u1 (2020-06-07) x86_64)
and version of 3cx is the last one ( 16.0.655 )
All theses calls are DirectSip.
Any ideas ?
I remember that some months ago, on windows, all were OK on this listing.
You would have to define in more detail what you mean by Direct SIP.
Is the PBX involved at all in the call?
I use SIP ID (Must be unique per extension)
[Extension / Options] to call registered user.
And I configured Settings for Direct SIP Calls
[Network Settings / FQDN]
So I can call the user 'Elisabeth' (extension1024) by Elisabeth@mydomain
The call is ok, no problem.
On Dashboard, I can see the number of calls (5/16 for exemple) but when I click on 'number of calls in use', the list is empty.
When I go to call history, I get my listing of call :
ex:
12/03/2020 12:32:03 PM type: 11, dn: DirectSIP Elisabeth (4123) 00:21:47
12/03/2020 10:55:31 AM type: 11, dn: DirectSIP Elisabeth (4123) 00:04:36
I have no trunk, I use 3CX as a gateway beeween a call center and external users logged on 3cx.
Jean-Luc
... So I can call the user 'Elisabeth' (extension 4123) by Elisabeth@mydomain...
hughesdouglas
