Active in Queue Not Changin
Ascent Support
Hello, I have a bit of a weird one and not sure if this is a bug or not.
when I am within the web client in 3CX and changing the Q status of a logged in user (not the availability) if you place the Q on everything works fine, however if you remove the Q in the background they are removed from the Q but this does not sync back to their web client or soft phone?
Has anyone else come across this?
Kind Regards
Peter
Hello @Ascent Support
Please note that there is the Global login/logout and the explicit login/logout. When someone else is login an extension from a Queue the extension will stop receiving calls and it will appear as Logged out in the Switchboard. But the Q button on the top of the Web client will not change as the global status of the extension is still logged in.
Good Evening,
You gave me information perfectly. Appreciate it!
If I can ask secondary, how would you stop agents from shadow logging out?
Kind Regards
Peter Charlton
Glad i could assist. The Q manager can see that agents are logged out by looking at the switchboard so that is a way to monitor the agents. You can also run a report regarding the agent login logout if someone cannot monitor the queues.
cmedina
