Solved Activity Log Filter
techdummy
We are currently running SP6.
When we try to filter the Activity Log, it doesn't seem to provide us with the filter options.
The only filter option available is "All Extensions". Previously we were able to filter using the extension number, which seem to have disappeared.
For the time being, the Activity Log Filter is useless!
Does anyone else have the same issues?
Can someone from 3cx please check on this?
Thank you.
Filtering works fine on all my installs. You don't mention what browser you are using but make sure it is one of the supported ones and try clearing your cache.
@cobaltit I'm using FireFox and the issue is still there even after clearing the cache.
I dont think it is an issue with the browser, as the same browser shows the Log for another instance.
Restarting the services have solved the issue.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
WAFI
