mjafari Silver Partner Advanced Certified Joined Feb 15, 2022 Messages 6 Reaction score 5 May 8, 2024 #1 I am running 3cx v20. The Add template feature under CRM Integration is not responding. Its greyed out. Has this been disabled in v20? Attachments temp.png 94.7 KB · Views: 11
Evolute IT 3CX MVP Gold Partner Advanced Certified Joined Feb 6, 2018 Messages 11,248 Reaction score 7,110 May 8, 2024 #2 Because you're not running Pro/Enterprise. It says it in the header. Reactions: edossantos_sipcaller
mjafari Silver Partner Advanced Certified Joined Feb 15, 2022 Messages 6 Reaction score 5 May 8, 2024 #3 Its a pro version. And all those other PRO features are working.
Evolute IT 3CX MVP Gold Partner Advanced Certified Joined Feb 6, 2018 Messages 11,248 Reaction score 7,110 May 8, 2024 #4 Try refreshing the license from the System > License page, then reboot/restart services. It may not have applied properly. Reactions: edossantos_sipcaller and Charles_3CX
mjafari Silver Partner Advanced Certified Joined Feb 15, 2022 Messages 6 Reaction score 5 May 8, 2024 #5 Thank you. I have restarted the services and it has worked. Reactions: edossantos_sipcaller and Evolute IT
TheodorosG_3CX Staff member 3CX Support Joined Jan 21, 2020 Messages 4,515 Reaction score 1,434 May 9, 2024 #6 If the PBX did not activated for a long time this can be caused. When it comes to features related with license edition, keep in mind to refresh the license to ensure if this is the case. Reactions: Evolute IT
