Adding area code
DrSpencer
Every number I try to dial from my IP phone or Click2Call gets area code 513 prepended to it. If I make a call from my iPhone app this does not happen. I can not see anywhere in my outbound rules that would cause this behavior. I have reset the IP phone and still have the issue. A couple weeks ago this issue was not present and I have made no system changes since the.
Hi there.
Not sure exactly what is there, however if you go to Advance > E164 and disable that option, will it make a difference?
I do not have Advance anywhere. Here is what is in my event log:
LevelEvent IDDate & TimeSourceDepartmentDetails
Warning3005207/05/2024 8:56 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 5138003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:52 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 5131800 that Ext.48310 dialed.
Warning3005207/05/2024 8:49 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 5138003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:48 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 513988 that Ext.48310 dialed.
Warning3005207/05/2024 8:48 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 51318003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:34 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 51318003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:33 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 5138003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:32 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 51318003310500 that Ext.48310 dialed.
Warning3005207/05/2024 8:25 AMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 5138003310500 that Ext.48310 dialed.
Warning3005207/03/2024 12:27 PMSIP ServerSol-Tech Technologies, LLCThere was no user or outbound rule found for the number 51318668390463 that Ext.48310 dialed.
Outbound Rules:
Rule Name
Calls to numbers starting with prefix
Calls from extension(s)
Calls to numbers with a length of
Calls from Departments
Add
Make outbound calls on
Strip digits
Prepend
Outbound caller ID
Route 0
CallCentric (Sol-Tech Technologies, LLC)
Route 1
Select Trunk
Route 2
Select Trunk
Route 3
Select Trunk
Route 4
Select Trunk
Rule Name
Add
Strip digits
Prepend
Outbound caller ID
Route 0
Route 1
Select Trunk
Route 2
Select Trunk
Route 3
Select Trunk
Route 4
Select Trunk
Rule Name
Add
Strip digits
Prepend
Outbound caller ID
Route 0
Route 1
Select Trunk
Route 2
Select Trunk
Route 3
Select Trunk
Route 4
Select Trunk
Its makes a bit difficult to read here, you dont need to paste with so many spaced.
So error seems to show that the rule dont have your user in there.
You can try create a new rule, place it on the top, only add that user there and correct prefix.
aatroxadrian
