Adding bulk DID's in V20
Mick Lenton
Gold Partner
Is there a way to do this in V20. There is an import option but not a export option to create a template file..TIA
You can import under the Sip Trunks<<DID number tab.
You will need a normal txt file and put the DID number in order.
How do I do this without having to type all the did range? Do you need a comma to separate all of the induvial numbers?
You can create a txt file and set the numbers in order, for example like:
+12345678
+12345677
+12345668
To create this txt file with a huge numberrange like 00-99 you can use excel and export it as txt file.
Reactions: TheodorosG_3CX
Yes both solutions can work.
tohoken1
