Solved Admin Console in Multi-Tenant Mode
tcit.nick
We are going to be deploying a multi-tenant configuration, so to prepare myself, I took my NFR tenant and set the LIMIT_PICKUP_TO_GROUP and MULTICOMPANYMODE to 1. I then saw the Multi Company menu and it was enabled.
I set up a couple of departments with extensions and Shared Parking per https://www.3cx.com/docs/multi-tenant-configuration/
At that point, I wanted to see what the admin console permissions looked like for users within separate companies. However, the Admin menu doesn't open for anyone with a permission level less than System Administrator or System Owner. Is there something else that I need to do be doing?
Thanks!
Did you define a department with extension numbers and added users into that department which are not in any other department on the system?
Thanks Nicholas. Being part of multiple departments was the issue.
Reactions: NicholasP_3CX
Graham Robertson
