Solved Admin Console UI Internationalization issue
NCIA
On a Version 20.0 Update 1 (Build 731 Release) English/US system:
Date should be MM-DD-YYYY not DD.MM.YYYY
Time should be AM/PM format
Duration of call "minuty" is a non-English word
Hi there.
If you go to the settings of the specific user,
and then set it in there US :
I have just tried this on my 3CX System with the same version and build and get expected outcome :
@NCIA did it work out for you after applying the above?
Reactions: NCIA
This setting was already configured to English (US), so I changed it to English (UK) and then back to US. Things are displaying properly now. Thanks for the direction.
Reactions: OlegR_3CX
Perfect, and thank you for the update as well as the feedback provided too, as your workaround can be helpful to someone else there in case facing the same issue.
I will now close this thread.
mazet
