admin login denied
IMI
SOHO User
It has been working fine unit recently. I tried to login with admin credentials but I cannot. I keep getting an error message (even though credentials are correct).
Error Message: "Login access denied. Too many incorrect login attempts. Try later or contact the Administrator."
- I am logging in with admin creds.
URL: <FQDN>:5001/#/login
Has something changed? -or has someone (malicious) attempted to login too many times? -security is set to block unknown IPs.
Hoping to get some help here, thank you...
Regarding your question, this indicates that you have enabled console restrictions and the IP address you are trying to access the management console from has not been added.
Since the system is on-premise, access the management console from another local computer and add your public IP, from where you are accessing the system remotely, to the console restrictions.
You can also log in directly to the management console from the Windows-based 3CX System machine and do the same.
Hi Charles,
To add more clarity, it is not on-premise, rather it is self-hosted with a cloud provider (effectively same type).
I am not able to access the server remotely. The 3CX system (server) is up and working - meaning calls, extension, etc., are running fine. Unfortunately, I need to administer somethings but cannot get in. Also, remote server reboots have been executed (including a stop and start too).
Hi Charles,
Windows or Linux? Do you have remote access to the machine?
You just have to get "on-net" to the PBX - inside the same subnet if possible.
If Linux, you can use SH Port Forwarding https://www.3cx.com/community/threads/web-portal-locked-out-completely.69139/#post-303084 to get "on-net"
Charles,
It is Windows. I tried that earlier but was not able. I have an idea to try something else. I will come back soon to update.
Reactions: Charles_3CX
Hey Charles, I was able to hone-in to the core issue, which was public entry failures. I ended up having to replace the public IP. There must have been something wrong with it. So updated 3CX and SIP, so back to working again.
Though, I am wondering why the URL via FQDN (i.e., <FQDN>:5001/#/login) is still not working. I can remote into server just not that URL. Any thoughts?
Thanks!
A Pro license FQDN has a TTL of 6 hours, Enterprise 5 minutes. Does the FQDN point to the new IP? If not try restarting services, or setting the network/IP in 3CX to dynamic, wait a bit, and back to static.
Hi there,
It is Enterprise and is pointing to proper IP. I had restarted the services followed by a server restart too. It had been over 24 hours. Anyhow, I took your advice to try the dynamic-static toggle. I waited first time for a couple a minutes and then retried again by waiting 16 minutes. Neither worked.
Thanks for suggesting, any other thoughts to fix this...
What is “not working” then? If it’s the same console restriction/login failure as above then it’s the same solution noted above, connect from an IP that’s allowed aka on the server’s network.
The system and server are running fine. Just cannot access admin console for 3CX via URL. I can only access if I remote into server and then connect.
Yes, I am attempting from an allowed IP.
Maybe (IDK) with a recent update the URL is not allowed? - even on enterprise?
Have you checked the console restrictions section under the management console > Security > Console Restrictions, If this is set to 'Allow Access from specific IP Addresses', and if so, the IP address from where you are trying to access the management console is added?
D'oh, that was it. I had updated the 'IP Blacklist' to 'allow' but forgot that one. So silly of me ‍- thank you!
(been using 3cx for over 10 years) I have an on prem 3cx - for over 3 years and am happy!
setting a new 888 for a new company.... so
I created a SMB hosted - (because of firewalls etc.) - couldn't get the new on prem server as fast as in the past! new internet issues etc.
so, I got SMB hosted running after a certain amount of time (more than I thought)
that was last week.
I come in this week and go to the web client and I logon with the initial account that I setup which in an admin account righty?
https://xxxx.3cx.cloud/webclient
No problem
then i want to do some admin stuff - so i trying to login to
I messed up the password or username - its not clear - then it gives me:
"Login access denied. Too many incorrect login attempts. Try later or contact the Administrator"
I am the admin - so what am i doing wrong?
Please help - this is URGENT
Steve
ps
i tried to post this elsewhere and i got this error
Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator.
ok - this helps - I am so used to the on prem version.. Now I just need to figure out how to manage ext outbound rules!!!
it is different !!! Thanks so much!
There are no outbound rules to configure.
On SMB there is much less to configure as on a On Prem
Reactions: bitn2
AshleyStokes
