after setup the 3cx System and add ip phone , the extension appear twice for one account in ip phone , gxp1625,gxp1630 and gxp2170
mahmoudomar
i do all this , the extension appear twice again
It literally says it cannot be changed.
yes , that after the add ip phone and assign the extension he take the provisioning and reboot and appear with twic eextension
On the BLF or in the phones tab in MGMT console?
in MGMT Console
one account take 2 line key , how remove this
i read the link and do all steps but shown one account in 2line
i think that problrm in templete and the license for 45 day trial from partner
can fix that issue
can send the templete for gxp1625,gxp1630 to see can modify or no
It's normal to have two line keys. Grandstream provided the template to 3CX and requires two line keys.
You can contact Grandstream directly and ask them to provide you with a modified template if you want, but we do no support modified templates - this might break the phone and it will not work correctly.
According to our remote session, we figured out that the issue was related to the line keys that were configured with the same account number, changing the line keys configuration from the 3cx template didn't solve the issue, this is due to a software bug in firmware version 1.0.7.13 which is fixed in firmware version 1.0.7.18. But 3cx only supports until 1.0.7.13, so we can do nothing about this. I suggest that you contact 3cx about this
how can fix that issue
There is no issue here to fix.
If you want to change the way the phone behaves, I think you should better ask Grandstream directly.
SupportRock
