After upgrade from last newest version 18.x to version 20.x the webadmin access for 3CX administration doesn't work
Alcasys
After get the same login as: admin and passw: customized value the system get me message Server error
Petr Halberstat
V20 does not have a web interface anymore as in the management page.
Or do you get an error in the webclient?
Do you mean ex https://fqdn.3cx.cz:5001/webclient ?
If yes, after also this access repeating reconnection but without connect.
The console access as root user on the vmware working right also by customized password
You need to login with systemowner credentials not the old admin or root login.
After add systemowner as account what password is used ? https://fqdn.3cx.cz:5001/#/login
It is a new account with some default password ?
The systemowner with previous admin password not work.
You need to set the password by yourself...Did you set the account as systemowner without configuring the account?
Yes.
So on the vmware console is need first create a new systemowner account include password ?
Yes.
What? That has nothing to do with vmware....
But I checked systemowner by vmware console under root access, but he not exist.
What are you talking about? This is 3cx not vmware. Maybe the best way is to have a look for a partner in your area that will help you.
You didn't understand me, my labdemo system 3CX is installed on the our vmware ESXi.
The console I mean root access to my labdemo 3CX system.
If you said me that admin access for web administration isn't possible on the upgraded version 3CX from 18.x to 20.x and
requesting a new account systemowner, after my task is as : create a new account to 3CX system for administratioin under root access on the 3CX console ?
No, you did it allready before upgrade. An upgrade to v20 isnt possible without systemowner account. you can try to reset the passwort to get access again.
Do you mean before upgrade 3CX from 18.x to 20.x create by web administratiion a new account : systemowner ?
Because, I didn't before upgrade a new account. Therefore he doesn't exist in 3CX system.
The reset password by methode email account doesn't work error 502
An upgrade isnt possible without systemowner account. So there is allready an account you made to systemowner. You need the email address and the password. Also if you get an error 502 there as lot more not ok on your 3cx. Ask your partner or have a look for an partner that will help you.
Ok, I must recovery install back to version 18.x include restore database and after create a new account systemowner and next step upgrade to version 20.
You can try this if you want, but for me it looks like you need some help with 3cx.
mazet
