AI Receptionist compability to EU-GDPR
JiPa
since AI is included in our license, I wanted to look into it and possibly let AI handle some basic calls.
But I see only "OpenAI" as provider. - I am not so familiar with the AI regulatory field yet, but I am with other DSGVO / GDPR topics. And everything I read about the way how it works seems to me that it will be very tough if not impossible to legally use an AI receptionist in 3CX as it is setup right now in EU/Germany. You wouldnt be even able to switch to OpenAI EU servers since you can only enter an API key if I am not mistaken?
Did anyone get it to work legally in germany? What are the steps?
Not legal advice, just adding to the discussion.
EEA entities opening an account with OpenAI would normally do so with OpenAI Ireland. The agreements provided cover their role as a Data Processor and are GDPR compatible via SCCs.
Even with the global endpoint URL, you should choose the relevant options when setting up your account with them to ensure that the maximum amount of processing stays within the EEA.
But 3CX will still hit the global endpoint URL right?
Yes, at this time the endpoint URL being used is the global one and not configurable from within the PBX.
It should be noted that OpenAI themselves do not support the full featureset, especially for audio, on their EU-only infrastructure, missing some of the latest models.
While I cannot know your specific requirements, if GDPR compliance is the metric, then that is achievable while using the global endpoints. If the aim is for no single data packet to cross outside the EEA, then it's a different mater.
In the US we need HIPAA compliance and OpenAI will provide us with the correct configuration and BAA.
However, its US only, so the endpoint becomes us.api.openapi.com/v1 - the global URL is prepended by "us." Everything works exactly the same.
Since we can't change the endpoint we can't use it. Ouch.
I believe it should be mention that we do have a solution that gives you the flexibility to use any OpenAI (or other provider) endpoint, even if not as simple as the build in voice agents in its setup:
https://www.3cx.com/blog/docs/programmable-extensions-ai-providers/
https://www.3cx.com/docs/agentic-call-control-ai-providers/
https://github.com/3cx/agentic-call-control
And an AI generated guide on how to set the relevant endpoint:
To invoke EU-specific endpoints for GDPR and data residency compliance within the 3cx/agentic-
call-control repository (specifically the examples/openai-realtime Programmable Extension), you
need to configure the underlying OpenAI / WebSockets client to point to OpenAI's European endpoint
([https://eu.api.openai.com](https://eu.api.openai.com) / wss://eu.api.openai.com) or
an OpenAI-compatible EU proxy/gateway.
Because agentic-call-control uses an SDK (such as openai Node.js client or raw WebSockets for real-
time WebRTC/audio sessions), the default target is api.openai.com.
Step 1: Update the Node.js OpenAI Client Base URL
If your Programmable Extension uses the official OpenAI Node.js SDK or standard REST call initializations, you
must override the baseURL parameter:
1. Open the initialization file (typically found in examples/openai-realtime/src/ or index.ts).
2. Locate where the OpenAI client is instantiated (e.g., new OpenAI(...)).
3. Set the baseURL parameter to the EU endpoint:
import OpenAI from "openai";
const openai = new OpenAI({
apiKey: process.env.OPENAI_API_KEY,
// Direct OpenAI EU Data Residency Endpoint:
baseURL: "https://eu.api.openai.com/v1",
Note: OpenAI requires an API Project/Organization explicitly created in the EU region in your OpenAI platform
settings for eu.api.openai.com requests to be accepted.
Step 2: Update the OpenAI Realtime WebSocket Endpoint (If Applicable)
Because examples/openai-realtime connects to the OpenAI Realtime API via WebSocket connections
(wss://), check where the WebSocket connection is established.
1. Look for the WebSocket instantiation string or base host URL configuration (e.g.,
wss://[api.openai.com/v1/realtime](https://api.openai.com/v1/realtime)).
2. Update the WebSocket host to the EU target:
// Standard Global WebSocket Endpoint:
// const wsUrl = "wss://api.openai.com/v1/realtime?model=gpt-4o-realtime-preview";
// EU Data Residency WebSocket Endpoint:
const wsUrl = "wss://eu.api.openai.com/v1/realtime?model=gpt-4o-realtime-preview";
Step 3: Pass via Configuration File (config.yaml or .env)
The recommended pattern in agentic-call-control is to avoid hardcoding API URLs. You can expose this
as a configurable setting in config.yaml:
1. Edit your config.yaml:
appId: "YOUR_3CX_APP_ID"
appSecret: "YOUR_3CX_APP_SECRET"
pbxBase: "https://your-pbx-domain.com"
openaiApiKey: "sk-proj-..."
# Add custom base URL parameter
openaiBaseUrl: "https://eu.api.openai.com/v1"
2. Pass openaiBaseUrl from your configuration into the client initialization:
apiKey: config.openaiApiKey,
baseURL: config.openaiBaseUrl || "https://api.openai.com/v1",
Alternative: Azure OpenAI Service in EU Regions
If you are using Azure OpenAI Service (which provides guaranteed EU data processing via regions like
sweden-central or france-central), configure the AzureOpenAI client SDK instead:
import { AzureOpenAI } from "openai";
const openai = new AzureOpenAI({
apiKey: process.env.AZURE_OPENAI_API_KEY,
endpoint: "https://<your-resource-name>.openai.azure.com/", // EU Region Endpoint
apiVersion: "2024-10-01-preview",
deployment: "gpt-4o-realtime-preview",
Compliance Verification Checklist
1. OpenAI Organization Settings: Ensure your project is set to the Europe region inside the OpenAI
Platform Dashboard. Standard api.openai.com traffic routes to US servers by default.
2. Data Processing Agreement (DPA): Confirm a signed DPA with OpenAI or Microsoft Azure to satisfy
GDPR requirements for processing personal caller data over the PBX.
3. Recording & Audio Transcripts: Ensure audio recordings and transcriptions generated by agentic-
call-control are stored within compliant EU storage backends.
Reactions: NatalyS_3CX
Zexus
