- Joined
- Jul 19, 2016
- Messages
- 100
- Reaction score
- 79
Let's assume an AI Receptionist.
It discusses with the caller, and transfers the call to a queue, ringing agents with the call context (John Doe is looking for a new car, request is urgent).
My goal is to retrieve this context to insert it into a CRM, especially when call has finally been missed.
I was then thinking about a CRM integration, but then, is the call context available as a variable in the CRM templates ?
Do I perhaps need to record the whole call and to transcribe it, then using the [Transcription] and [Summary] variables (seems like a heavy / resource consuming workaround) ?
Any other solution I would have missed ?
Thank you very much !
