allow few country only
MITIIMS
I would like to authorize certain extension to call some country, and other to call worldwide, is it possible with 3cx. ?
Yes, through outbound rules. For example, specify which extensions are permitted to call phone numbers beginning with 044, and another outbound rule that block calls from the specified group/extension to 044.
yes but can you imagine the number of country !!!, that will take me 10 days !! :eek:xD I was thinking using CFD but I did not find the way to do that. and if in 3cx I allow all country, the one in the department international will have access to all country instead of few.
Perhaps you do not need an outbound rule for every country NOT permitted. Rather, only create rules for what IS permitted and everything else would be automatically rejected.
While you absolutely could create a CFD that asks for the number to dial, then places the call (if allowed), that seems like a pretty invasive approach. I do not think the outbound rule approach is as big of a job as you are envisioning.
hpgitsupport
