Allow international calls / disable call barring ?
catherder-cowboy
Is there a simple and quick way to allow all international calls without the need to check every single country in the Security.
The country allow list is global and you have to select all countries to enable them.
You can however construct outbound rules that block certain user groups and allow others to have access to international calls based ie. on the number length
Thanks for your help.
I am in the process of setting up a 3CX system for an internationally operating business. As the current system is laborious I would appreciate a feature that would make this easier in future versions:
  • white / blacklist option (either choose what you want to block or what you want to allow).
OOPS I just discovered that the system actually chooses all countries when you check the continent, but not when there is a single country selected. So there is actually an "All Countries" option - it's just not obvious for a newbie on 3CX.
3K8iMGWviZ
