Allow Reassigning the Default Fax Extension to Free Up 8888
ASheng
Platinum Partner
On systems with 4-digit extensions, the Fax Server automatically takes extension 8888 (888 on 3-digit systems), and this number cannot be changed or released.
3CX Support confirmed that changing it is not supported (tested on V20 Update 9).
In Chinese-speaking regions (Taiwan, Hong Kong, China, Singapore, etc.), the number 8 sounds like 發 (fa, "prosperity"), so 8888 is a highly desired number.
Many of our customers want to use 8888 as a normal extension or dial code, but they can't, even when they don't use the fax feature at all.
Suggestion:
- Allow administrators to change the Fax Server extension number in the Admin Console, or
- Allow the Fax Server extension to be removed when fax is not used, so that 8888 can be assigned as a normal extension.
This would let customers use 8888 on their own PBX without any unsupported workaround.
If you would also like this feature, please vote.
Thank you!
Upvote 0
LeeonLau
