Solved Allow remote bridged 3cx server users to use local external lines
YahyaFlaifel
I have two 3cx servers connected via bridge, I need to allow either 3cx server users to use external lines of the other server, i.e. users from (PBX1) can make external calls using SIP trunks connected to (PBX2) and vice versa. Is this possible using the bridge connection or I must create separate sip trunk? and HOW?!
Yes that's simple:
- Configure the bridge
- make your outbound rule on PBX1 that just use a prefix then sends everything to the PBX2
- on PBX2, have an outbound rule that is 100% opened so that calls can go out.
We do that all the time.
Reactions: YiannisH_3CX
Yes that's simple:
Thank you!
I have configured outbound rules with prefix in both sides and they are working.
lastshadow
