Amazon or Google or ....
vectra
Platinum Partner
What is your experience which cloud solution works best to host 3CX?
it is a simple question of:
  • Price per Instance
  • Are you already familiar with one
  • What do you like more
On the availability score, both have a very good track record - nothing to worry about.
I have good experiences with OVH as cloud solution.
Do you have plans to supports other Cloud platforms such as Vultr, DigitalOcean or IBMcloud?
@Frederick Marcoux support in terms of pbxexpress ? Otherwise feel free to install a 3CX at Vultr, DO, upcloud etc. works great so far ;)
Yeah I know, I have Vultr. But what I mean is AWS and Azure are supported by 3CX which means they will help you if the problem is coming from your vnet or else. Currently, if using another provider, the supports stops at 3CX itself (which is fine).
hughesdouglas
