Solved Android app hangs on Team, Contacts, and Voicemail, MyPhone notification stream times out on multiple phones
blackacoustic
I am seeing an issue with the 3CX Android app where Team, Contacts, and Voicemail load forever on two different Android phones / extensions.
What works normally:
  • Calls
  • Provisioning
  • SIP tunnel
  • Call history
  • Web Client
What fails:
  • Android app foreground use still hangs on Team, Contacts, and Voicemail
  • The issue happens on both Wi-Fi and mobile data
  • The issue happens on two separate Android phones
PBX environment:
  • 3CX version: 20.0.9.995
  • Repository channel: production candidate
  • Deployment: on-premise / self-managed
  • License: BASIC Edition, 4 SC
Android app environment:
  • Android app: 20.7.0.5
  • At least one affected phone is on Android 17 / API 37
What I already tried:
  • Reprovisioned both extensions
  • Removed and re-added the account on the phones
  • Updated the Android app from Play Store and retested
  • Disabled battery optimization
  • Enabled background data
  • Restarted 3CX services, including Management Console, System Server, and Call Flow services
  • Tested on both Wi-Fi and mobile data
Verbose log details:
  • Authentication succeeds
  • MyPhone session creation succeeds
  • Then the app repeatedly logs onNotificationStreamFailure (SocketTimeoutException) - timeout
  • After that it logs stream fail, relogin
Because the issue happens in foreground use, on multiple devices, and on both Wi-Fi and mobile data, it does not look like a background push or battery optimization problem. It also does not seem related to SIP registration, call history, or the Web Client.
If anyone has seen this before, I would appreciate guidance on whether this is a known Android app / MyPhone stream issue for 20.7.0.5 with PBX 20.0.9.995, and whether there is a supported production fix or update.
Thank you.
Hi thanks for your feedback.
Could you kindly send us verbose logs of the issue?
Hamburger Menu > Settings > Advanced
Scroll all the way to the end and enable Verbose logs
Reproduce the issue and send us the logs
Scroll all the way to the end and tap on send log report.
Please attach me these logs via Personal message. You would probably need to upload the logs at your preferred cloud storage provider and send me the shareable link.
I send them to you thru DM just let me know if you were able to access it
We looked into the logs. Could be possibly a firewall issue.
Could you kindly login into webclient from the phone itself and see if the issue is reproduceable?
I was able to test from the webclient, i'm able to login thru the web on my phones data and make calls and see teams, chat, calls, planel voicemail contacts and interact and use them properly. its just the app away from the main network.
I figured it out, 443 was blocked on my side so i opened up 5001 and routed it to there and it started working. i got the green square at the top fully functioning.
Reactions: KyriacosS_3CX
LeeonLau
