Android app not showing Ring groups or Queues
Paultechnica
Platinum Partner
Hi all,
The 3CX android app doesnt show the ring groups or queues.
The windows client does show the ring groups or queues...
Is this a common issue or ?
I've searched the forum for quite a bit but it seems i am the only one.
Hope to hear something :)
Thanks in advance
Is anybody experiencing the same?
Anyone?
The alternative is adding the groups/queues as contacts but then youll see it double in the (working) windows clients...
Hi Paul,
If you mean they don't appear in the list of extensions when you tap on Status?
If so, no they do not appear in the app.
Hey JohnS,
Nope even the Status doesn't show ring groups / call queues
They do appear in the windowsclient/webclient...
DejanMDS
