Antivirus on Debian 3CX ISO
caccamo
Is it possible to install antivirus like clamAV or MDE on 3cx debian based server? Which files/paths should be excluded?
That is neither supported nor recommended. Why would you want to do that?
For compliance. Can you direct me to piece of official documentation that mentions it is not recommended/supported?
Also what will happen if I obtain info about important 3cx files to exclude from scans and still go ahead and install it?
You can do whatever you want, of course, but running a virus scanner directly on a VoIP system is never a good idea. 3CX’s policy is that nothing should be installed on the PBX; if you do so anyway, it is unsupported, and you lose your entitlement to support from 3CX. Aside from that, I still don't understand what purpose a virus scanner would serve on a PBX.
@caccamo, for compliance requirements, I'd recommend using the built-in Remote Syslog feature instead of installing third-party antivirus software on the 3CX server. It allows you to forward operational, security, and audit logs to an external Syslog/SIEM platform for centralized monitoring.
You can read more information in our blog post here: https://www.3cx.com/blog/releases/custom-remote-syslog-logging/
BConveryCoreCare
