Solved Anyone having trouble with downloads.3cx.com?
drewt
Something broken, can do all my updates and install dataplicity, but no sbc software download.
Try downloads-global.3cx.com . Sounds like the guide hasn't been updated.
no route to host is a network config error on the device itself.
Most 3CX hosts do not respond to pings, so that's normal
That was it, as soon as I used updated global downloads url it worked. I was able to install my monitoring software and ping the internet, the sbc install would only fail with no route to host. can we get the guide updated?
Turns out I did have an error in /etc/dhcpcd.conf file. I had correct namservers of 8.8.8.8 and local gateway, but my routers=192.168.1. was missing last number. I could download packages for dataplicity and 3cx etc but 3cxsbc would not start, even after downloading correct packages from downloads-global.3cx.com. I had partial internet access, enough to download packages, but not enough for 3cxsbc to start up after install.
Reactions: YiannisH_3CX
devo.it
