API Access - Only possible on Enterprise now?
This_guy_here
I am trying to find an easy way to programmatically get a list of active extensions with names on a monthly basis. We manage a number of 3CX systems and want to provide an "active user" summary each month. In the DOCS section I see "3CX Configuration API" which shows that the configuration API requires Enterprise license.
Is there still any other way to gather this data via an API on Professional license?
With a 16SC and more licence it can definitely be done via the data connectors, even aggregating multiple remote systems into one remote DB that you manage and generate custom reports from.
For build in reports, the Extension statistics provides that data, and XAPI should allow you to fetch them programmatically.
Oh, that's very interesting! Any chance there is any documentation that could point me in the right direction to try this?
Graham Robertson
