API or AI integration - HELP
PeterChef
New User
I have 3CX for my business and would like to connect it through Make.com so I can integrate with other software, I am aiming to do the following.
- Transcribe calls and save into ZOHO - ideally through fireflies.ai
- Log calls in ZOHO
Can anyone help me with the best way to achieve this?
It seems like other VOIP services like dialpad or aircall have great integrations - is this something 3cx are looking at doing? Or are there work arounds?
Pete
You can already log calls into Zoho using the CRM integration. 3CX doesn't have a public API that can be used for any of this. So, make.com won't work. Zappier either.
As for transcribing, this isn't available directly in 3CX. You will need a custom addons for this. It's also pretty expensive usually since recordings can be huge.
Also, StartUP doesn't support any of this.
ummm - I might need to look at other phone systems
Of course, if you're looking for something free, you won't find a lot.
You can always buy a Pro 4SC license and have the full 3CX dedicated system, and not the very limited StartUP.
Then, you'd have more options for integrations.
lonedigger
