App Return Call from log Caller ID
RodTech
Trainee Partner
Android App
5 DID's on Twilio Trunk
When returning call from Recent calls the caller id shows the main did's caller id. Is it possible to show the caller ID of the DID the caller called? The outbound call is being routed thru the number the caller used to call.
FROM+121****1660 TOsip:+19*****[email protected]
CALLED VIA (940) ***-8811 <------ This is the number the caller used to call and its being used to return the call but not showing that number as the caller ID
DIRECTION Trunking Originating
The easiest way (and I'm not 100% sure this would work) would be to create 5 extensions (1 for each DID) and put them in a ring group. You'd set the caller ID per extension to the 5 separate DIDs. Then have your phone registered to any one of them. You'd provision all 5 accounts on your android app. You'd have to switch accounts before calling out based on which DID they called. In theory the call history should be the same on all 5 extensions but I'm not sure. You might want to test it by making one extension and calling it from another. It should go straight to VM since nothing is registered. Then switch accounts to that extension and see if the missed call still shows in the history so you can return it.
Schnittker
