Solved Attended transfer by default
David_K
Hello
In all our extensions, in Phone Provisioning / Select transfer method used (Blind or Attended) when you press a DSS key, we have "Attended" that is selected. (the other option is Blind Transfer)
I was hoping that by doing that, as soon as we press a BLF key, it will trigger an Attended transfer.
But it triggers a Blind transfer, each time.
Is this a bug or did I understand incorrectly the option?
You understood correctly, but please reprovision the phone to apply the change.
Thanks @JohnS_3CX
Just reprovisionned the phones using the reprovision button, but same behavior
When you say reprovision, you mean factory reset the phone and then reprevision it?
OK after rebooting the phones it's working
(I've also forced to change the phones from French to English, to see it the re-provisioning was working and it was)
Reactions: JohnS_3CX
Glad to hear it was resolved
EMMEPICASA
