Solved audio conference limitations
house1
Forum User
i have a need for several separate simultaneous audio conferences. Can
UserA send out a conf invite to his group of 3 individuals for a 10am audio conference on 11/29
UserB send out a conf invite to her group of 4 individuals for a 10 am audio conference on 11/29
and
they are 2 separate conferences
Does the invite get sent with 2 separate conference codes?
ASSUMING we have the correct license counts, is there a limit on simultaneous conferences (NOT WebRTC)
and
For WebMeeting, yes they will be separated. The limit is by participants, not the number of conferences.
As for audio conference, the only limit is the SC of your license.
This old article mentions a limit of 32 users in a conference call:
https://www.3cx.com/blog/voip-howto/create-conference-using-desk-phone/
And in a similar thread apparently I found another reference that had the limit at 128:
https://www.3cx.com/community/threads/conference-call-limitation.59231/post-248685
Perhaps @JohnS_3CX or @YiannisH_3CX can clarify
You can have multiple independently concurrent conferences, each has its own conference ID. The conference ID is 4 digits so you get 10.000 rooms theoretically (0000-9999).
Maximum number of participants across all conferences is limited only by your license SC.
thanks gents
Kayla Norris
