Audit Log "Performed By" is always same user
Mark Phillips
V18
I have enabled SSO for the global administrator role, but the Audit Log always shows the non-SSO administrator username in the "Performed By" column, rather than the SSO username. I am definitely logged into the Admin Console using SSO.
Is this normal?
Hi @Mark Phillips,
It is normal, yes. If you're logged in to the global admin account via SSO, then you are in fact the admin. If you've added an extension to the User Sign In and the same email address to the Administrator Sign in section of the SSO for Google for example, the PBX will select the highest privilege to log you in with.
Okay thanks - that makes sense. Still, it would be a nice idea to show the SSO username ;-) I'm sure that lots of 3CX installs have more than one person carrying out the global admin duties.
Hi @Mark Phillips,
Yes, I see what you're saying with regards to having multiple admins logging in to the same admin account. If you'd like to add the feature request to the Ideas forum, feel free to contact a 3CX Partner to post on your behalf.
WagnerFT
