Australia – Which GSM gateway / Cellular Gateway / Fixed Cellular Terminal / PABX Mobile Interface to 3CX work with 3CX (Cloud v20 / On‑Prem)?
yudixasmara
Hi all,
I’m looking to hear from anyone in Australia who has successfully connected a GSM gateway / Cellular Gateway / Fixed Cellular Terminal / PABX Mobile Interface to 3CX, either Cloud (v20) or on‑premise.
I have received mixed reports about these devices now being blocked by Australian carriers since the 3G network shutdown.
Specifically, I’d like to know:
  • What brand and model of gateway you’re successfully using
  • Which Australian carriers it is working with (and plan types)
If you are successfully using one with a phone system other than 3cx, we'd also love to hear from you.
Thank you in advance
Yudi
this is your 3rd post on pretty much the same topic.
I would refrain from creating posts for the sake of "being at the top" and unnecessarily spamming the board.
keep it to your one post and just post replies in there to "bump" the post.
You can try doing a search for GSM gateways on the forum or looking at the 3CX Supported gateways.
ARKC
