Auto-Answer
Mohamedseliem
Forum User
Hello everyone, hope you're doing well
Is there any way to get auto-answer enabled?
Ver. 18
In the app, under ... > Settings > Audio/Video, there's a checkbox for this.
Firstly thank you
Then, this can done by picking up the call automatically yes
But agent can change it
As I explained, the option is in the Webclient.
Yes, users can change it. Just don't tell them.
Am I blind or what ? ... where is "that" auto-answer option under Audio/Video ?
Oh ... it's in the 3CX Desktop app not the web
Just checked webclient and i cant find it there either , so yeah probably only available in the Desktop app
TVV40
