Auto Dial
sst_ekell
Intermediate Cert.
Background: Polycom phones and 3CX Pro v16
Behavior: User dials number on phone handset and then must press the Dial button to initiate the call.
Request: The client's old phone system would dial the number for the user instead of waiting for the dial button to be pressed. if they waited like 2 seconds. The client would like this same functionality in 3CX. I'm not finding a setting that would enable that, can someone point me to how to make this change?
Thank you!
You would have to create yourself a phone template and edit the dial plan timeout so that it dials when it detects xx digits or after xx seconds of inactivity.
3CX MGMT Console > Settings > Templates
Copy your Polycom template and do a search for "digit" which will take you to where you need to be.
I dont use Polycom so im not entirely sure what info needs to be set.
you could try exporting the config from a phone and looking at the current "Dial Plan Settings" to see if you can see the variable set there. Maybe you'll find dialplan.userdial.timeout="x" which you could set and apply to your custom template.
SpacetelSupport
