Auto provisioning of Yealink phones after factory reset?
ProudCanadian
Scenario: I have a Yealink T46S at my desk on the latest firmware. After playing around with the settings, I want to get it back to stock condition so I factory reset it.
Currently, after doing so it appears bold in the phones list in 3CX, and I have to manually click assign extension and choose myself again before 3CX provisions it.
Is there some way to have 3CX see this new phone appear, realize its already assigned to an extension and then just provision it automagically?
Reactions: NateDoc
Thanks @NickD_3CX yes they are on same physical LAN and Subnet. But I also can run down the hall and test as a Remote Phone. Both fail in the same way.. never shows up in Phones page as New or as Provisioned
your comment: "Run a packet capture on the server, you can do that from the MC as well" ? please explain how. I'm assuming MC = Management Console (the 3CX server is on Debian)
@Imaxinar DM
A few key pieces of information, The Yealink phone and the 3CX Server, and they on the same LAN/Subnet? I ask because you said that you tried Remote STUN as well.
Also, if the Yealink and the 3CX Server are behind the same ZyXEL Router, NATing should not play any role, although it does look correct. Mutlicast of course must be allowed.
So, working with the assumption that the phone and the server are on the same physical LAN and Subnet, the first thing I would suggest looking for is why the phone is not showing up in the Management Console. Run a packet capture on the server, you can do that from the MC as well, Factory Reset the phone amd wait until it comes back online. If it doesn't show up in the "Phones" node, open the capture file with Wireshark and check for the source IP of the phone with something like:
Code:
ip.addr==[IP of Phone]
This should tell you if the server received any information at all from the phone (so its a good starting point).
Remember, if phone and server are on different subnets, usually multicast packets won't reach one another...[/QUOTE]
Sorry, yes MC = Management Console.
Easy:
  1. Log into the MC.
  2. Go to Dashboard --> Activity Log
  3. Press the "Capture" button
  4. Reboot phone and wait
  5. When done, press "stop"
  6. Download
  7. Open w/ Wireshark (you need to download this separately on your PC)
AshleyStokes
