Auto Update Failing to 16.0.6.655
Adrian S
New User
Hi all, I am getting this error while trying to auto-update to 16.0.6.655
Any idea's?
Hit:1 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
Hit:2 http://downloads-global.3cx.com/downloads/debian stretch InRelease
Hit:3 http://repo.saltstack.com/apt/debian/9/amd64/latest stretch InRelease
Hit:4 http://archive.repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: libfreeimage3 but it is not installable
E: Unable to correct problems, you have held broken packages.
Rollback to 16.0.6.655...
3cxpbx is already the newest version (16.0.6.655).
The following packages were automatically installed and are no longer required:
iputils-ping libarchive13 libavahi-client3 libavahi-common-data
libavahi-common3 libcap2-bin libcups2 libdbi1 libldb1 liblzo2-2
libmariadbclient18 libnet-snmp-perl libpam-cap libpython2.7 libradcli4
libsmbclient libsnmp-base libsnmp30 libtalloc2 libtdb1 libtevent0 libtirpc1
libwbclient0 monitoring-plugins monitoring-plugins-basic
monitoring-plugins-common monitoring-plugins-standard mysql-common
python-ldb python-samba python-talloc python-tdb samba-common
samba-common-bin samba-libs smbclient snmp
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
Thanks in advance
Easiest thing to do would be to backup, copy it off, nuke the machine/vm/cloud instance and then do a fresh install and restore.
I agree with cobaltit, you seem to be missing important Debian repositories, hence why it cannot fins package "libfreeimage3" which is indeed required.
Take a backup, download it off the Linux machine, then start over following these instructions:
https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
fransisco
