Autoprovisioning ATAs
Roberto teste
Hello everyone!
I would like to know if there is any way to autoprovision ATAs. Is there a list of supported ATAs, ones that I can configure without doing it manualy, device by device on the web page?
There is not currently any offially supported ATA devices, gateways only.
https://www.3cx.com/voip-gateways/
What models are you looking at and reason for provisioning? Most are pretty simple to setup manually.
Hello @Roberto teste
Depending on your requirements on of the supported devices could provide the required functionality. These devices come with configuration guides which usually require you to either set the provisioning link in the device or upload the configuration file generated by the 3CX phone system.
gmacinit
