@MysterC925
While there is legacy support for the
9608G, the J100 is not supported.
This means that 3CX does not have built-in templates for automatic configuration of that model, nor has it been tested for interop compatibility. In this case, you might still be able to get it working using support provided directly by the manufacturer so you can extend their life longer.
Do note however, that we do not recommend purchasing unsupported phones because there is never any guarantee they will work as intended. You might find strange behavior like:
- hold/unhold not working right
- transfers might fail
- no audio/one way audio problems might appear in certain situations
- BLF and DND might not work
- phonebook will not be available
If you have the ability to upgrade, or plan to do so in the future, take a look here to see what models we do support:
https://www.3cx.com/sip-phones/
