Solved AWS Debian 10 v18 with 1 CPU upgrade issues
MitchellSTL
So I used 3cx to create my pbx almost 2 years ago. Like the title says, it's worked fine with just 1 CPU, but version 20/Debian 12 wants two CPUs. I was hoping to create a snapshot of my current system and then create an instance (but with 2 CPUs) from the snapshot. But I got this fun message...
This bundle size isn't compatible with the selected blueprint debian_9_5. Choose a different bundle.
Any idea on how to upgrade my current Debian 10, Version 18 with 1 CPU to something that I can upgrade to Debian 12, Version 20 with 2 CPUs?
Do a full backup of the system. Then shut that VM down created a new VM with the specs for 3CX install 3CX and apply the back up config to it. Then do the upgrade.
Reactions: jed and MitchellSTL
Check also the Cloud Provider plans here for more information.
Sorry for taking so long to respond. Had to go thru and check everything was working correctly in the new server before deleting AWS instance. @mgroom thanks for the advice, that worked. @TheodorosG_3CX will do - thank you!
Reactions: jed and N_G
You are welcome ;)
mazet
